FS playback component (ReferenceError: Error #1056: *HELP*
COW Forums : Adobe Flash
Aisha Nelson
on Sep 2, 2009 at 3:36:35 pm
My problem is that my full screen component for my flv player isn't working.
When I view it in "TestMovie" it doesn't work at all. When I publish it, it goes to full screen but immediately the screen goes black. Then the flv doesn't playback correctly.You can still hear the audio.
I am getting the error:
ReferenceError: Error #1056: Cannot create property flvPlayer on flash.display.Stage.
Is there anyway I can fix this issue? Is there some kind of fscommand I could add?
demetri tashie
Re: FS playback component (ReferenceError: Error #1056: *HELP*
on Sep 3, 2009 at 2:54:18 am
hi aisha,
getting Full Screen Video to work can be frustrating. You aren't giving that much information to go by. I think i know the process you are trying to emulate using import flash.display.Stage; etc
and setting displayState to FULL_SCREEN
following that method should work, but i know people have problems with it.
if you are open to another method, you can follow along this not too long explanation of mine at:
it really just involves hacking the AC_RunActiveContent javascript from your Flash published file and inserting it into your desired web page, making sure to turn "allowFullScreen = false" values to "true"
sorry if i am not exactly answering your direct question - but you might want to try this method instead
© 2018 All Rights Reserved
