Convert XML Data into Numbers
COW Forums : Adobe Flash
Tony Ingrassia
on Aug 17, 2009 at 5:08:23 pm
What I'm trying to do is control the length of a timer through XML. Here's my code:
stop();
var timer_xml:XML;
var xmlReq:URLRequest = new URLRequest("variables.xml");
var xmlLoader:URLLoader = new URLLoader();
var topTextTimer;
var timerDelay:int = parseInt(topTextTimer);
function xmlLoaded(event:Event):void
timer_xml = new XML(xmlLoader.data);
topTextTimer = timer_xml.image.toptexttimer;
xmlLoader.load(xmlReq);
xmlLoader.addEventListener(Event.COMPLETE, xmlLoaded);
import flash.utils.Timer;
var pauseTimer:Timer = new Timer(timerDelay, 1);
function playTopText (event:TimerEvent):void
play();
pauseTimer.addEventListener(TimerEvent.TIMER, playTopText);
pauseTimer.start();
So, as you can see, I'm loading the XML data from an external file (variables.xml). Using the above code, when I preview I get no errors, but the timer does not work. However, if I go to the timer controls (where you set the delay and repeat values) and add...
var pauseTimer:Timer = new Timer(timerDelay+5000, 1);
...it works! It's almost as if the action script is seeing my timerDelay variable as having a value of "0"
I know that the XML data has to be converted from a String to a Number, and I thought that using "parseInt" would accomplish this.
What am I missing?
