Jagged outlines when animating PNGs
COW Forums : Adobe Flash
Louis Hudson
on Aug 12, 2009 at 3:49:44 pm
When animating PNGs with transparency, the quality can get very jagged depending on the angle of the image. I've noticed this on quite a few website and banners using bitmaps, but was wondering whether there's a quality setting that needs changing or a work around.
Flash can be a quicker alternative to After Effects, but this problem limits me to AfterFX.
Louis Hudson
Re: Jagged outlines when animating PNGs
on Dec 12, 2009 at 5:25:11 pm
Found out the answer. Right click the image in the libaray. Select 'Properties' and tick 'Allow smoothing'.
Bit dumb that it's not set by default, but there you go.
