Using .mov files
COW Forums : Adobe Flash
joey williams
Using .mov files
on Jul 31, 2009 at 2:42:51 am
I have video files I want to use, but I'd rather use .mov instead of .mp4/flv. How do I get Flash to use .mov?
JW
TOAD ARRAY
http://toadarray.com
Fernando Mol
Re: Using .mov files
on Aug 8, 2009 at 4:33:27 pm
You can't.
*Remember to share a link to your site and to rate the posts. This is a free service for you and for us.
joey williams
on Aug 9, 2009 at 6:17:48 pm
OK. Thanks.
You have any suggestions for the best way to encode video for Flash? I'm using Adobe Media Encoder now, but I'd like to use Compressor.
JW
TOAD ARRAY
cowcowcowcowcow
Fernando Mol
on Aug 9, 2009 at 6:33:26 pm
Sorry, but I'm not familiar with Compressor.
The compression parameters for creating a good flv file will be different from video to video. Those are some of the important ones:
Image size
Bitrate
Framerate
You need to get a good balance between image quality and compression, that will totally depend on your video. Transitions, camera movements and changing subjects (trees on the wind, water on a river) can be very demanding. The more still your image, the better compression you'll have.
I'll assume you have defined the size of your image. For the web 15fps is a good framerate. And for a bitrate you'll need to consider your target audience. Testing is unavoidable.
joey williams
on Aug 10, 2009 at 12:28:34 am
Thanks for the info. I'll give these some good testing.
I'm curious to see what the differences in frame rates do. I shot most my stuff in 30fps, so I usually encode it as such. I'll definitely try 15 and see what that shakes out.
JW
TOAD ARRAY
