How to make a final SWF "rounded" not square
COW Forums : Adobe Flash
Cornelius Matteo
on Jul 27, 2009 at 10:33:39 pm
Hi Everyone,
How can I create my final SWF file to have rounded edges and not just be a square? I have a vendor who requires my banner files (swf's) have rounded edges.
Cornelius
cowcowcowcow
Clint Milner
Re: How to make a final SWF "rounded" not square
on Jul 28, 2009 at 11:33:29 am
I'm not sure if swf can actually "have" rounded corners, but you can create the illusion of it having round corners by making a mask.
1. At the very top of your layer stack create a new layer named mask.
2. Hold down on the rectangle tool and choose the primitive rectangle tool.
3. Create a rectangle the same size as your stage and in the properties panel, select no stroke and any color for the fill. Also, in the rectangle options section, you can add the amount of round-ness to the corners.
4. Right click on the mask layer and select mask. you'll probably see the layer icon directly below the mask will move to the right slightly. If you have any layers that haven't moved over, you can manually move them over one by one.
5. The published swf will have round corners.
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
Cornelius Matteo
on Jul 28, 2009 at 4:46:57 pm
Thanks .... worked perfectly.
Cornelius
