Converting from MOV to FLV
COW Forums : Adobe Flash
Doug Weihnacht
on Jul 20, 2009 at 7:07:54 pm
I'm about to convert 150 MOV files to FLV. Is there a freeware application available that does this well? If not, what's the best option? Compressor? Movie Cleaner?
cow
Desiree Damon
Re: Converting from MOV to FLV
on Jul 23, 2009 at 8:33:30 pm
I don't know what software you already have...
If you have Adobe Flash, you can use the Video Encoder that ships with it. If you're a Final Cut user, Quicktime Pro also has a setting to export to .flv
As far as free software, I know MPEG Streamclip (which you can get from http://www.squared5.com) has the ability to export as a .flv. The option isn't listed directly in the file menu. But under 'Export to other formats' it's a selectable option.
