Flash - Interactive Cube with reflection and floor
COW Forums : Adobe Flash
Michael Croog
on Jul 17, 2009 at 11:44:24 pm
I'm building this in Flash.
http://www.croog.com/interactivecuberoom
As you can see, when the mouse moves left and right, the cube (with reflection too) spins.
It's really just a stream of frames that change based on the mouse X position. Simply done to show the concept.
Now, Firstly, how do I make this box also react to the mouse's vertical movement and then have the cube, and the reflection, and the floor react to that mouse movement as well.
I also want to restrict the vertical movement as well so that you couldn't go past a certain angle. Like you couldn't be allowed to flip it upside-down for example. You would have to stay within certain controllable boundaries.
Also, as a controllable option, it would be nice if it had some sort of bounciness/friction to the interaction with the mouse.
Any help?
Thank You.
