Need help on Flash Interactive video
COW Forums : Adobe Flash
darvin gutierrez
on Jul 13, 2009 at 8:07:37 pm
I have a flash interactive video project
the videos is controlled by action script ver. 3
using cue points to move from chapter to chapter
I want the video to unload after playing
and go to an specific frame.
The interface has been created
just a problem on task bar progress, buttons
and video unloading.
demetri tashie
Re: Need help on Flash Interactive video( AS3 solutions)
on Jul 14, 2009 at 1:03:34 am
you can accomplish that a few ways.
you can add a cue point - an Event cue point - at the end of the video, and then just write the script that you want to accomplish.
or you can import and use the VideoEvent Class and its COMPLETE detection constant, and then tell the function to remove the player ( i assume that is what you meant by 'unload') , and then to go to whatever frame you want.
here is some code to help you with that.the code assumes an instance of the video player called "flvPlyer", and it will take you to frame 15 on the main timeline.
flvPlayer.addEventListener(VideoEvent.COMPLETE, remove);
function remove(evt:VideoEvent):void{
hope that helps
© 2018 All Rights Reserved
