Can't get FLVPlayback to close when I return to the main menu
COW Forums : Adobe Flash
Darren Kaulback
on Jun 29, 2009 at 8:59:13 pm
I'm creating a Flash DVD that has a number of menus that link to external videos.
Everything works fine. I can click between menus and play videos thru FLVplayback. When a video is done playing, it returns back to its appropriate menu.
BUT... the problem is - when I hit the Full screen button while playing back the video, the FLVplayback window doesn't go away when the video finishes. You can hear the menu music but there is no video.. just the empty full screen FLVplayback window.
I've tried to use action script to make the window invisible or to close down the player but I've not had any success getting either solution to work.
It seems that something is up with Full Screen playback. When I first start my projector.app file, if I select full screen from the upper menu bar, the menu resizes nicely but the videos do not play when the menu is Full screen. (that's a side issue... but possibly related.)
Any help or suggestions would be greatly appreciated!!
