Action Script 3 submenu buttons wont work
COW Forums : Adobe Flash
Allie Crawford
on Jun 28, 2009 at 9:45:01 pm
Hello,
I'm having a little problem in action script 3 and I can't find the little solution to it. If anyone can help, I'd be so grateful.
I have 6 main buttons in my website. When you click one of them called 'introduction' then the sub buttons should appear (which will link to an flv called 'SynchronizedVideoPres_12_fla'). I coded the first sub-button called 'motivations' and it works fine when its placed in frame 1 on the timeline, along with the other main buttons. (action script is in frame one also)
BUT
Obviously, the sub button is not supposed to appear until the 'introduction' button has been pressed. So therefore, I moved the 'motivations' button to frame ten so when you click 'introduction' it will just go to frame ten and show the sub button'motivations'
.....but now the sub buttons dont work and the movie clips on the main buttons dont play either(although they do show the non-working sub buttons when clicked at least.)
Im thinking I need to change the action script for the 'motivations' button so it can find the button in the timeline but I dont have a clue what to type as this is all Chinese to me.
I get this error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at SynchronizedVideoPres_12_fla::MainTimeline/frame1()
Here is the code:
// Stop the timeline
stop();
import fl.video.*;
import flash.events.*;
// Button hilite graphic
var highlight_mc;
// Associate full screen button with FLVPlayback
display.muteButton = mute_btn;
display.volumeBar = volume_bar;
display.stopButton = stop_btn;
display.playPauseButton = play_btn;
// Navigation buttons call this function to trigger a change
// in the video and the view of the content
function seekToCuePoint( cueName ) : void
// Find the cue point in the FLVPlayback component, seek
// to time, and highlight the next button for a quick redraw
var c = display.findCuePoint( cueName );
display.seekSeconds( c.time );
findNextButton( c.name );
// The natural flow through the video or jumping by seeking
// forward and backward will trigger the following function
function synchVideoToInterace( cueName:String ):void
// Play if needed
if(!display.isRTMP && !display.playing ){
display.play();
// Show associated content on screens or labeled frames
gotoAndStop( cueName );
// Update the higlight position
findNextButton( cueName );
// Layout the button highlight when requested
function findNextButton( cueName:String ):void
// Look for buttons named with the current cue point
// name plus the letters '_btn' (i.e. studiomx_btn)
if( getChildByName(cueName+"_btn") != null )
var cueBtn = this[cueName+"_btn"];
// Attach the highlight clip if needed
if( this["highlight_mc"] == undefined ){
highlight_mc = new ThumbOutlineSelected();
addChild(highlight_mc);
highlight_mc.x = cueBtn.x;
highlight_mc.y = cueBtn.y;
// Create event handler functions to catch events from
// the video component and update the interface...
function cuePointHandler( evt:MetadataEvent ):void
// Get the cue name from the event object
synchVideoToInterace( evt.info.name );
display.addEventListener(MetadataEvent.CUE_POINT,cuePointHandler);
// Button Event Handlers:
// Introduction
function introductionHandler(evt:MouseEvent):void
gotoAndStop('introduction');
introduction.addEventListener(MouseEvent.CLICK,introductionHandler);
// Tell a Friend
function allThingsLegalHandler(evt:MouseEvent):void
// Seek to cue point
gotoAndStop( "allThingsLegal" );
allThingsLegal.addEventListener(MouseEvent.CLICK,allThingsLegalHandler);
// finance
function financeHandler(evt:MouseEvent):void
gotoAndStop( "finance" );
finance.addEventListener(MouseEvent.CLICK,financeHandler);
// The Company
function theCompanyHandler(evt:MouseEvent):void
gotoAndStop( "theCompany" );
theCompany.addEventListener(MouseEvent.CLICK,theCompanyHandler);
// buyingAndSelling
function buyingAndSellingHandler(evt:MouseEvent):void
gotoAndStop( "buyingAndSelling" );
buyingAndSelling.addEventListener(MouseEvent.CLICK,buyingAndSellingHandler);
// Top Tips
function topTipsHandler(evt:MouseEvent):void
gotoAndStop( "topTips" );
topTips.addEventListener(MouseEvent.CLICK,topTipsHandler);
// Rewind
function rewindHandler(evt:MouseEvent):void
seekToCuePoint( "rewind" );
rewind.addEventListener(MouseEvent.CLICK,rewindHandler);
// Extra Information
function extraInformationHandler(evt:MouseEvent):void
seekToCuePoint( "motivations" );
gotoAndStop( "motivations" );
extraInformation.addEventListener(MouseEvent.CLICK,extraInformationHandler);
// Motivations
function motivationsHandler(evt:MouseEvent):void
motivations.addEventListener(MouseEvent.CLICK,motivationsHandler);
// Ideas
function ideasHandler(evt:MouseEvent):void
seekToCuePoint( "ideas" );
gotoAndStop( "ideas" );
ideas.addEventListener(MouseEvent.CLICK,ideasHandler);
import com.afcomponents.common.display.*;
import com.afcomponents.common.graphics.*;
function onRollover(pEvt:MouseEvent):void{
pEvt.currentTarget.gotoAndPlay("rollover");
function onRollout(pEvt:MouseEvent):void{
pEvt.currentTarget.gotoAndPlay("rollout");
//reflection
var style:ReflectionStyle = new ReflectionStyle();
style.distance = 2;
style.alpha = 0.6;
style.matrixRatio = 1;
//blue buttons
var r1:BitmapReflection = new BitmapReflection(rewind,style);
addChild(r1);
var r2:BitmapReflection = new BitmapReflection(stop_btn,style);
addChild(r2);
var r3:BitmapReflection = new BitmapReflection(play_btn,style);
addChild(r3);
var r4:BitmapReflection = new BitmapReflection(bt04,style);
addChild(r4);
var r11:BitmapReflection = new BitmapReflection(pause_btn,style);
addChild(r11);
//blue buttons
rewind.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
rewind.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
stop_btn.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
stop_btn.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
play_btn.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
play_btn.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
bt04.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
bt04.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
pause_btn.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
pause_btn.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
rewind.buttonMode = true;
stop_btn.buttonMode = true;
play_btn.buttonMode = true;
bt04.buttonMode = true;
pause_btn.buttonMode = true;
rewind.mouseChildren = false;
stop_btn.mouseChildren = false;
play_btn.mouseChildren = false;
bt04.mouseChildren = false;
pause_btn.mouseChildren = false;
//pink buttons
finance.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
topTips.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
introduction.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
allThingsLegal.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
theCompany.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
buyingAndSelling.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
motivations.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
extraInformation.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
ideas.addEventListener(MouseEvent.MOUSE_OUT,onRollout);
finance.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
topTips.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
introduction.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
allThingsLegal.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
theCompany.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
buyingAndSelling.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
motivations.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
extraInformation.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
ideas.addEventListener(MouseEvent.MOUSE_OVER,onRollover);
finance.buttonMode = true;
topTips.buttonMode = true;
introduction.buttonMode = true;
allThingsLegal.buttonMode = true;
theCompany.buttonMode = true;
buyingAndSelling.buttonMode = true;
motivations.buttonMode = true;
extraInformation.buttonMode = true;
ideas.buttonMode = true;
finance.mouseChildren = false;
topTips.mouseChildren = false;
introduction.mouseChildren = false;
allThingsLegal.mouseChildren = false;
theCompany.mouseChildren = false;
buyingAndSelling.mouseChildren = false;
motivations.mouseChildren = false;
extraInformation.mouseChildren = false;
ideas.mouseChildren = false;
sandra schmitt
Re: Action Script 3 submenu buttons wont work
on Sep 30, 2009 at 6:55:14 pm
Hello!
I am having the same problem were you ever able to fix it? If so could you post or shed some light? Or at least point me in correct direction of what to look up and try and to understand.
Thank you... if I figure out I will post too :)
thx s
