Animation Loop Code
COW Forums : Adobe Flash
Cutter Johnston
Animation Loop Code
on Jun 11, 2009 at 11:18:32 am
A while back I was asking how to continuously loop an animation . I did not receive any truly useful relpies. I did come up with a solution that is flexible, expandable and works great. Here is the code:
import fl.video.*;
stop();
var arrayNum:Number = 0;
var videoArray:Array = new Array();
videoArray[0] = "AnimationOfFlyingZits.flv";
var flvControl = playBack;
var flvSource = videoArray[arrayNum];
playBack.pauseButton = pauseBtn;
playBack.playButton = playBtn;
playBack.source = videoArray[arrayNum];
playBack.addEventListener(VideoEvent.COMPLETE, videoComplete);
function videoComplete(event:VideoEvent):void{
//trace(event.target.source);
if(event.target.source == videoArray[0]){
event.target.play();
The solution is in the EventListener for the playBack and the function below it.
Hope it helps someone with the same issue!
Cutter
demetri tashie
Re: Animation Loop Code
on Jun 11, 2009 at 12:54:43 pm
hi cutter-
nice solution ! shows good creative thinking.
food for thought: you could do it even more simply, without the bother of the array-
just:
import fl.video.*;
playBack.source = "YourVideo.flv";
Cutter Johnston
on Jun 11, 2009 at 9:28:55 pm
Understood. Actually this a scaled down version of a site that contains 12 animations. I just cut those from the code I posted. Thanks though. I will use this for publishing a single clip.
