FLV not showing in published movie
COW Forums : Adobe Flash
Brad Margerrison
on May 14, 2009 at 7:16:23 pm
Hi all,
I am new to flash but I do still enjoy learning how to use it. I am currently using flash CS3 to make a small flash project; only 4 scenes. On this project I would like to have videos.
Basically I imported some wmv files (one at a time for seperate scenes and layers) via file>import video. Using the flash encoder/wizard the program put the new flv files in the library and on the stage.
When I test the movie, (crtl+Enter) the videos work fine. But then as soon as I published the movie/project the videos disappear.
Can anyone suggest where Im going wrong and what i need to do to get them to work?
Any help is much appreciated :)
Justin P. Junda
Re: FLV not showing in published movie
on May 19, 2009 at 1:21:35 am
Did you embedd or link them as external flvs. Chances are you linked them and you dont have the right path to these files.
Justin P. Junda
Ivone Nina
Re: Flv does not appear in published movie
on May 27, 2009 at 1:29:44 pm
Hello, Brad
You already solved your problem com flv? If, Send the videos that you used for creating the Flash together com files to the host.
Abra├žos.
