Quickie- Issues importing .txt data
COW Forums : Adobe Flash
Tony Mazzarella
on May 7, 2009 at 11:00:19 am
Hey all,
Quick little frustrating issue. I'm updated certain parts of a flash site- was coded in AS2. I'm still working is AS2 in CS4.
I have a textBox instance that loads a file 'awards.txt'. The textBox is set to render the text as html as I have some styling coming in from a style sheet
Txt data looked like this:
Problem: Flash will not load the text inside of the span- so I don't have the styling. Do I have to re-work the structure on this? Can I pull in CSS directly into the actions frame? Right now I'm pulling it into a 'style.as'
Tony Mazzarella
Owner
Northeast Interactive
http://www.neint.net
Tony Mazzarella
Re: Quickie- Issues importing .txt data
on May 7, 2009 at 11:35:42 am
sorry txt is formatted as:
content=2008 <span class=award"> Award Name</span>
apparently tag isn't working, the award name is in a span.
Tony Mazzarella
Owner
