Help.. how to ensure that images is loaded according to the order in xml
COW Forums : Adobe Flash
lynn ooi
on May 4, 2009 at 2:46:43 pm
I had created a flash which load several images and display it using loadMovieClip(). I need the images to load in a specific order according to the information retrieve from a xml file. However, my scripts only works well if it was tested in my local computer. In online environment, the images seems to load in a random sequence. Do anyone have any idea to fix it so that the images loads according to the xml order?
Below is my scripts:
var myShowXML = new XML();
myShowXML.ignoreWhite = true;
myShowXML.load("galleryxml.xml");
myShowXML.onLoad = function() {
_root.myWidth = myShowXML.firstChild.attributes.width;
_root.myHeight = myShowXML.firstChild.attributes.height;
_root.mySpeed = myShowXML.firstChild.attributes.speed;
_root.myImages = myShowXML.firstChild.childNodes;
_root.myImagesNo = myImages.length;
loadAvatar();
createContainer();
callImages();
function loadAvatar() {
avatar.loadMovie(_root.myAvatar);
function createContainer() {
_root.createEmptyMovieClip("myContainer_mc",_root. getDepth()-1);
myContainer_mc.lineTo(_root.myWidth,0);
myContainer_mc.lineTo(_root.myWidth,_root.myHeight );
myContainer_mc.lineTo(0,_root.myHeight);
myContainer_mc.lineTo(0,0);
myContainer_mc._x = (Stage.width-myContainer_mc._width)/2;
myContainer_mc._y = (Stage.height-myContainer_mc._height)/2;
function callImages() {
_root.myMCL = new MovieClipLoader();
_root.myPreloader = new Object();
_root.myMCL.addListener(_root.myPreloader);
_root.myClips_array = [];
_root.myPreloader.onLoadStart = function(target) {
_root.createTextField("filename_txt",_root.getNext HighestDepth(),0,0,100,20);
_root.filename_txt._x = 70;
_root.filename_txt._y = 305;
_root.filename_txt.autoSize = "left";
_root.myPreloader.onLoadProgress = function(target) {
_root.filename_txt.text = "Loading.. "+_root.myClips_array.length+"/"+_root.myImagesNo+" Completed";
_root.myPreloader.onLoadComplete = function(target) {
_root.myClips_array.push(target);
trace(target._name);
target._alpha = 0;
if (_root.myClips_array.length == _root.myImagesNo) {
moveSlide();
if (_root.myImagesNo>1) {
myShowInt = setInterval(moveSlide, (_root.mySpeed*1000)+1000);
for (i=0; i<_root.myImagesNo; i++) {
temp_url = _root.myImages[i].attributes.file_preview;
temp_mc = myContainer_mc.createEmptyMovieClip(i, myContainer_mc.getNextHighestDepth());
_root.myMCL.loadClip(temp_url,temp_mc);
function moveSlide() {
current_mc = _root.myClips_array[_root.target_mc];
new Tween(current_mc, "_alpha", Strong.easeOut, 100, 0, 1, true);
_root.target_mc++;
if (_root.target_mc>=_root.myImagesNo) {
_root.target_mc = 0;
_root.filename_txt.text = _root.myImages[_root.target_mc].attributes.file_name;
next_mc = _root.myClips_array[_root.target_mc];
new Tween(next_mc, "_alpha", Strong.easeOut, 0, 100, 1, true);
