enable button in parent SWF AS2
COW Forums : Adobe Flash
Joshua Altman
on May 3, 2009 at 4:26:58 am
I designed a map in Flash and the popups load from external SWFs. Right now I can disable the button in the parent SWF but I cannot disable them from the one that is loaded (the button that unloads the SWF is in the child) below is my script.
_root._root._root.gotoAndPlay("home")
_root._root._root._level0.U1317.enabled=true
Any ides will be helpful
