Loading XML swf gallery inside another swf
COW Forums : Adobe Flash
Ben Mettler
on Apr 30, 2009 at 10:27:49 pm
So I'm trying to load an XML driven swf gallery inside another swf. So I have an empty MC setup that the swf gallery is suppose to load in to when a button is clicked. The problem is that it can't find the gallery.xml file.
It says 'Load XML failed
Error opening URL 'file:///C|/Documents%20and%20Settings/Benni/My%20Documents/New%20Website/gallery.xml'
This is the path I have in written in the AS on the btn that loads the gallery (AS2):
on (release)
fnShowTab(1);
loadMovie("simpleviewergalleryweb/viewer.swf", "emptymc");
Now it does work when I move all the files from the "simpleviewergalleryweb" into the same folder where the main swf resides, but I can't do that because I have two different galleries so I can't have two of the same gallery.xml files in there. This is a free gallery so I don't have access to the original FLA files. If anyone has any ideas I would be grateful.
