Zoom in a flash movie
COW Forums : Adobe Flash
Dotan Stern
on Apr 30, 2009 at 6:22:22 pm
i have a flash video of a product and i want the user to be able to zoom in and out using a button
also if its possible to be able to move around the object
what do i need to make it work?
does it have to be a 3D model using a 3D software or can it be a 3D using layers in AE?
also do i have to use a special player?
thanx in advance
demetri tashie
Re: Zoom in a flash movie (AS3 solutions)
on Apr 30, 2009 at 11:01:08 pm
for the zooming , you can try a few different ways: these ways will just zoom the actual FLVComponent ( or Movie Clip that it resides in ) . it won't give you full 3D manipulation. but here are things you could consider:
use the Transitions Class - look at the Zoom Class and play with that.
or more low tech you can of course script buttons to allow you to just change the scaleX and scaleY of the Component/Clip. that, coupled with some clever Masking, could give you some good Zoom effects.
Dotan Stern
on May 1, 2009 at 7:16:41 am
Thank you
ill make it simple what i want and tell me how can i do this
i have a 3D cube flv file
i want to have the finl video to show the cube with butons for zoom in and out and also button for rotaion
so when you press the zoom it zooms in or out
when you press and hold toe rotaion you can rotate around
is this something to do with scripts?
can someone post an example?
im new to flash
demetri tashie
on May 14, 2009 at 9:56:51 pm
hi. i am sorry i am just seeing your reply now. i hope someone else can jump in here, because i am not fluent in 3D projects.
i would be curious to see the 3D cube flv file to see how i/we can manipulate it. the theory should be the same as with other scripting functionality..
© 2018 All Rights Reserved
