AS3- external fl to layer
COW Forums : Adobe Flash
Joakim Werner
on Apr 21, 2009 at 9:46:00 am
Hello!
Here is my problem:
I have created a drop-down menu in as3 that contains different .flv's loaded from a site.
I can load any flv video without a problem.
Once one movie has loaded and is playing, I can't access the drop down menu. I think the problem is that the movies load on top of the layers within flash, and hiding everything that is under.
It should be possible to load a movie to a particular layer, the question is how. Should I use a var for a particular layer?
Or is there a smarter way to do this?
Thanks for your help, very much appreciated!
Here is my placement code:
//AS3 for loadmovies
var Xpos:Number = 189;
var Ypos:Number = 25;
var swf:MovieClip;
var loader:Loader = new Loader();
loader.x = Xpos;
loader.y = Ypos;
addChild(loader);
demetri tashie
Re: AS3- external fl to layer
on Apr 21, 2009 at 1:08:47 pm
use addChildAt(loader,0); instead of just addChild(loader);
addChild places that child at the top most 'z-order' ( stacking order - analagous to the top layer, if you created it on the stage) of the Display List ( how objects are viewed in the exported SWF)
using addChildAt(0) tells it where to be on the z-order of the display list. 0 is the lowest. depending on your other objects in your file, of course, this should place it below your drop down. if not, change the number and see what happens.
Joakim Werner
on Apr 21, 2009 at 5:20:49 pm
Worked like a charm.
Thanks for your help!
demetri tashie
on Apr 21, 2009 at 5:23:10 pm
great !
