Floorplan help
COW Forums : Adobe Flash
Anne Gilbert
Floorplan help
on Apr 20, 2009 at 8:22:41 pm
I need help! I am new at AS3 and have a project (that is way out of my league) that has been dumped into my lap.
THE PROJECT: An interactive floorplan that allows a user to zoom in/out, and place a pin (red dot) on their office location and view where others have placed their pins (yellow dots). Also, a bubble pops up on rollover of the yellow dots with the users photo thumbnail, name, email and phone number.
SO FAR: I have been able to create the floorplan and have it do the zoom/pan. A RoR developer on my team has been able to start the integration with the user information but needs me to hook up the dots to each user.
THE PROBLEM: I created the floorplan with zoom/pan - it worked. The developer added his RubyAMF code - it worked. I created a separate file that inserts the red dot with rollover - it works. I try to do the exact same steps in the original floorplan file as the separate file - IT DOESN'T WORK!
I'm getting errors like:
1046: Type was not found or was not a compile-time constant: ProgressEvent
Warning: 1060: Migration issue: The method Play is no longer supported.
Warning: 1060: Migration issue: The method Stop is no longer supported.
I've attached a sample of my file and can provide .as codes if needed.
My structure is:
/flash/zoom.fla /flash/zoom.swf
/flash/FloorMap.as
/flash/lib/com/innova/onedegree/floormaps/UserLocation.as
/flash/lib/com/innova/onedegree/floormaps/InfoPanel.as
I'm hoping someone could help me - any help would be greatly appreciated!
-Frustrated
