Novice help with Flash Buttons
COW Forums : Adobe Flash
Mysty Carol
on Apr 10, 2009 at 8:33:38 pm
Hi! I've created a button in flash, and I've tested in in Flash. It works. However, I'm having some problems. First, when I insert the file in my html page, it shows up as a size of 550x200 px. In fact, the image itself shows up the correct size, and is only around 130x50 px. However, it shows up on the website with a large white background, which seems to be including the stage in flash. Can someone please tell me how to fix this?
Graham Quince
Re: Novice help with Flash Buttons
on Apr 11, 2009 at 10:05:09 am
Your flash stage size may be set to 550x200px. The white default background colour blends in a little too easily on the light-grey workspace so you mightn't have realised. Set your flash stage to the same size as your image and when you generate your html code it will use this size.
Graham - Free FX for amateur films
© 2018 All Rights Reserved
