Line weight
COW Forums : Adobe Flash
Jeff Cochran
Line weight
on Apr 3, 2009 at 7:39:40 pm
I'm importing Illustrator files into Flash. Each of these files have a lot of black lines with a specific line weight. When I get them into Flash, I have to resize them to different sizes. When I do resize them, the line weight doesn't seem to change and ends up very heavy when all I need is for the line weight to scale down with the rest of the graphic.
Is there any way I can fix this problem in Flash?
Thanks in advance.
Pieter Helsen
Re: Line weight
on Apr 3, 2009 at 10:56:49 pm
Select the lines, then go to the properties panel and where it says 'Scale', choose 'Normal' from the dropdown box.
I'm guessing it's currently set to 'None'.
Kind regards,
General notice: from now on, I would like to ask everyone to put [AS2] or [AS3] (corresponding to the version of actionscript you are using on your project) in front of their post titles when the question is actionscript related! Please help us help you faster. Thank you.
© 2018 All Rights Reserved
