Flash integration w/ Final Cut
COW Forums : Adobe Flash
steve turcotte
on Apr 3, 2009 at 3:02:45 pm
I'm having a nightmare trying to figure out the right sequence settings for editing a Flash document in Final Cut.
My Flash document aspect ratio = 1280 x 720
*What would be the best export setting to use?
Also what would be the ideal AV settings & sequence settings be in Final Cut?
I've tried various combinations, but my animation sequences are usually a bit skewed and need rendering.
Are there any settings that would allow me to edit together Flash Quicktime sequences without rendering?
Steve
Tony Ross
Re: Flash integration w/ Final Cut
on Apr 4, 2009 at 9:18:53 pm
Import your Flash-Quicktime movie into Final Cut
In the browser, right-click on the movie
Select Make Multi-clip Sequence… from the menu
You should now have a Sequence, Multiclip Sequence 1, that matches the settings of your movie exactly.
I usually just use H.264 when exporting from Flash. Here is a tutorial on how I export:
http://tinyurl.com/tonyteach006
keep it simple, make it perfect…
steve turcotte
on Apr 23, 2009 at 6:56:08 pm
Thanks Tony. That make everything so much easier!
Steve
