Problem publishing or exporting movie
COW Forums : Adobe Flash
Dindhick Fruiter
on Mar 14, 2009 at 3:12:55 pm
I am using flash cs3 professional on a mac. I created an animated logo and when attempting to publish it or export it I used all the default settings. The flash movie was created but when I attempted to play it the screen was black. I moved around on the screen and found the movie to be there, playing but very large and only one piece visible no matter what I attempted. I tried again, making it 1/2 the size of the original but with no success. I tried creating a quicktime movie but upon exporting it the screen was black as well with no movie anywhere to be seen.
When viewing the animation on the stage it's position is in the lower right hand corner, as it was in the SWF. I tried moving it to the center but the animation fell apart. I tried grouping the layers first but the same thing happened. When it is moved to the center it doesn't fill the entire white square. I tried scaling it but no success.
(Obviously I don't know much about Flash)
I would appreciate any assistance or methods of solving thiis problem.
Thank you,
