quicktime to swf help
COW Forums : Adobe Flash
Jason Richards
on Mar 12, 2009 at 3:44:29 pm
I have a quicktime from After Effects I need to take into flash and export out as a swf. I figured flash would do a better job compressing the file than AE ? Basically my quicktime is about 3mb and I need to get it down to around 40 or 50k. Oh, and how do I control the compression settings in Flash when I export the swf movie.
is this easy to do ?
thanks for any direction
JR
Todd Morgan
Re: quicktime to swf help
on Mar 13, 2009 at 6:21:12 pm
Have you tried exporting to .swf from AE already? If this was not up to spec, then I recommend using Squeeze.
Jason Richards
on Mar 13, 2009 at 6:28:53 pm
Yeah, I tried that. I guess I'm having issues trying to get anything down to 40k which doesn't seem realistic for any type of web ad. But heck I know nothing :(
Todd Morgan
on Mar 13, 2009 at 6:32:41 pm
It also comes down to what content you have in your creative. If you have effects and/or bitmapped images, they will add to your file size. If you have mostly vector art the files size will be lower. Try a test and export to .swf from AE with all layers that have bitmaps turned off and you will see a big difference in your file size.
Min Lee
on Oct 2, 2009 at 10:33:14 am
is there a way to export .swf from AE? i exported a flash file but it had the extension .flv. that would indeed save me time and money.
Todd Morgan
on Oct 2, 2009 at 3:47:25 pm
Under FILE>EXPORT and it will be there.
