.mov to swf file exporting issue
COW Forums : Adobe Flash
nella pelligra
on Feb 26, 2009 at 3:02:19 am
I am boggled down by this current issue I can not resolve.
I am able to import a .MOV file into CS3 Flash no problem. I am able to complete the entire process of converting the file. However when I go and play the file once I close the Flash CS3 program, I am running into an audio issue.
Prior to importing the small video clip (@ 35 second clip), hte sound and video are in sync. However, after I export the .SWF file the sound was WAY off. The first time I completed this task, the audio sounded robotic and extrememly slower than the video clip action. The second time I did this the .SWF video and audio play together in sync then @ 5 seconds into the video the audio completely stops and the video continues to play. I am using this video clip for a website I am creating in Dreamweaver CS3. I have also had this same issue with other .MOV video clips. Any suggestions as to how to get the audio and video in sync when I import the clip into Dreamweaver would be much appreciated. Thanks.
© 2018 All Rights Reserved
