HEEEEELPP!! simple btn>goto actiosncript problem
COW Forums : Adobe Flash
Elin grome
on Feb 25, 2009 at 5:36:45 pm
Hi People,
Havent used flash in years - and wasnt a great coder when i did, but have been using Cs4 to put together a simple linear animation.
At the end of the animation i want to it to stop, with a button available for the user to restart.
This used to be easy - but in AS3 im lost.
Now, ive figured out that i have to put the code on the frame, not the button, but still having problems, can anyone help?
Heres my code;
stop();
ENDBTN.addEventListener(MouseEvent.CLICK,MouseClick);
function MouseClick(e:MouseEvent):void{
root.gotoAndPlay("start");
Where ENDBTN is my button instance and "start" is a frame label at frame 1.
The problems are;
• When i test it the animation doesnt stop :s - must be something to do with the code that follows cos the stop() funciton alone works fine.
I get a compiler error "call to a possibly undefined method GotoAndPlay..." blah blah...
god, this used to be easy.. please help . quite urgent.:(
Elin
It's all the those pesky details :p
Elin grome
Re: HEEEEELPP!! simple btn>goto actiosncript problem
on Feb 25, 2009 at 5:46:27 pm
ha! so dont know how/why - but just removed "root" and now it works.
:s
demetri tashie
on Feb 25, 2009 at 5:56:37 pm
some possible things to look at:
1) make sure that your ENDBTN is actually called that as it's Instance name ( you can set this in the Properties Inspector) this is probably an overlooked issue.
2) is this all on happening on just a main timeline? then i don't think you need 'root.gotoAndPlay' . try just gotoAndPlay("start") . also - make sure there is a Frame Label called "start"
3) try also evt:MouseEvent rather than e:MouseEvent
try those ( one at a time) and get back if it works - let us know and learn from this example too !
