re: changing color of titles/graphic files
COW Forums : Adobe Flash
Ira Liss
on Feb 9, 2009 at 11:29:18 pm
I have 10 titles, mostly single words, created by using the Flash text function. I then added drop shadows by right/clicking into "timeline effects." Then I converted these text files into graphic files so that I could use the Color/Alpha function to fade these titles up and down.
All of these titles were the same color when I began typing. Now, the client may want all titles to be a different color. Is there way I can change all these titles at once?
It would get a bit laborious to type out each title all over again -- in a new color, add drop shadow, adjust position, add Color/Alpha function, fade up, down, etc. Please advise.
(I suspect there's an ActionScript way to do this. Unfortunately, I don't have a lot of experience making changes with ActionScript. If the solution is there, may I gently ask for advice suited for the ActionScrip beginner?) I appreciate your help. Thank you very much!!!
© 2018 All Rights Reserved
