Should be a easy ?.
COW Forums : Adobe Flash
trent jones
Should be a easy ?.
on Jan 30, 2009 at 9:30:01 pm
Hello.
My name is Trent, and I just got Adobe Flash CS4 - for kicks and giggles.
I've just composed my first animation project.
I'm running into a problem, that I am hoping some1 can give me an answer too.
I built the animation from content I made in illustrator.
I put together the whole animation, then "published" it using Flash CS4.
Now, when I test it, or open the file on my computer - it works fine.
But, I emailed the file to a couple of friends, as a test - and its just a blank .html page for them.
Afterward, because I am using Illustrator CS2, I converted all of the content to .png files, and substituted the layer targets.
But, that didn't work either.
Graham Quince
Re: Should be a easy ?.
on Feb 2, 2009 at 9:36:00 am
I have this problem all the time, are you emailing your friends all three files which are produced? The web page, the flash file and the file called AC_RunActiveContent.js ?
If you are, are your friends downloading all three files to their documents/downloads area before running?
Normally I find it easiest to zip up the files, email that zip with instructions on accessing at the other end.
Graham
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
