A few problems...
COW Forums : Adobe Flash
George Kemp
A few problems...
on Jan 27, 2009 at 4:16:56 am
Hi everyone,
I have just picked up flash cs4 last Sunday(trial version). I've sucsessfully created my friends band a flash website which I'm pretty proud of. My only problem is how they can edit it without adobe flash... Can it be done?Also can I edit it when my trial runs out with another program? Any help or suggestions would be apprciated my me and my friends. Thanks
Daniel Toennies
Re: A few problems...
on Jan 27, 2009 at 4:53:07 pm
You can not edit a flash site with out FLASH because of the directory. of ".fla" You cant treat a flash document like an HTML because it is different.
You can edit it with any other flash such as cs3 if you have it. Or even flash 7. However you need to be aware of the AS3 problems and make sure you know what AS your using.
But to answer your question, from what i know, you cant use any problem but flash to edit a flash file, hence, any swf and so on so forth.
© 2018 All Rights Reserved
