Loading external FLV into SWF i need a solution!
COW Forums : Adobe Flash
kyle knoblauch
on Jan 27, 2009 at 2:26:53 am
i run rep215.com if you go to http://www.rep215.com/index.htm under 'captured' you will see how there is no video loading, im guessing this is because its too large. the flv that is suppose to be loading was included in that swf file. there has to be another way to load flvs without including them in the published swf.
i want to be able to put different videos up here all the time but, i need a better way for me to do this. help me out please.
Tim Flora
Re: Loading external FLV into SWF i need a solution!
on Jan 27, 2009 at 6:07:08 am
sounds like an issue I was having, you may want to look at this thread.
http://forums.creativecow.net/thread/190/863308#863386
http://www.filmeditingtips.blogspot.com
