Changing URL on the end of a Flash video
COW Forums : Adobe Flash
Peter Berthet
on Dec 10, 2008 at 5:59:45 am
Hey guys,
Im somewhat new to actionscript, and while i understand how it works im at a loss as to how the hell i get this happening.
Basically what i have is a FLV that is an intro to a website, so it loads, plays once, then what i want it to do once it ends is to automatically kick the browser over into the new website
at the moment what i have is an actionscript driven flv inside a flash project, with the following code
var nc:NetConnection = new NetConnection();
var ns:NetStream = new NetStream(nc);
ns.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);"h264_comp_2.flv");
function asyncErrorHandler(event:AsyncErrorEvent):void {
and that works to make it PLAY once, if anyone has any suggestions as to how i can make it forward the browser id be very thankful
Sam Mattern
Re: Changing URL on the end of a Flash video
on Dec 15, 2008 at 3:27:39 pm
Just detect the end, and upon detecting it, call a getURL. The NetStream sends a status of "NetStream.Play.Stop" when the playback has finished. Check it like this:
ns.onStatus = function( oData:Object):Void{
if( oData.code == NetStream.Play.Stop ){
I also verify it's at the end checking the time against the duration (rounding needed), but that's up to you. You can see more about doing that here:
© 2018 All Rights Reserved
