How to stop the timer
COW Forums : Adobe Flash
Manny Rellesiva
on Dec 4, 2008 at 12:09:12 pm
Im trying to create a stopwatch in a game and saw this link and was very helpful:
http://www.actionscript.org/forums/showthread.php3?p=375393
Howver, my problem is how to stop the timer? Is there any function or method/property in Flash to stop the time/r? Thanks in advance
manny
Graham Quince
Re: How to stop the timer
on Dec 6, 2008 at 8:47:13 am
I'd do this by creating a go-nogo option.
On your starting frame, set nogo = "no";
On your start countdown button, above your start timer code put this line in:
_root.nogo = "go";
On your countdown code, frame it all with this 'if' statement:
if (_root.nogo == "go") {
Then on your pause button simply use:
_root.nogo = "no";
This might need refining and you'll have to something for starting the timer again. I'm not at my flash PC right now, but there's a couple of different ways to sort out the unpause button. (either a second play statement or visisble/invisible buttons)
Hope that helps
Graham
http://www.YouTube.com/ShiveringCactus - Free FX for amateur films
