Scroll Bar Not Scrolling.... Sometimes
COW Forums : Adobe Flash
Jacob Resendez
on Nov 21, 2008 at 5:31:34 pm
hello,
i have a simple flash piece that dynamically loads .swf files into empty movie clips in my main movie. in one of the loaded swfs, i have a scrolling text box that works just fine on its own, but when it gets loaded into the main movie, it does nothing. i assume there is some line of code that i do not have. if necessary, i can post the code i have used. thanks in advance.
Sam Mattern
Re: Scroll Bar Not Scrolling.... Sometimes
on Nov 26, 2008 at 3:28:46 pm
Most probably some of the code is out of scope. Testing scope is as simple as putting a trace(0); inside the scroll function. Verify that you get a 0 output in the output panel when testing alone. Then test your main movie from within flash to see if you kick a 0.
-Sam
