AS 3.0 flv playback: close upon completion
COW Forums : Adobe Flash
walt landy
on Nov 12, 2008 at 5:08:35 pm
hi all,
many thanks in advance for any help with this.
i'm working on an interactive ergonomics guide (playback from disc), where one of the modules has a picture of a workstation where users click on a button over the chair/monitor/keyboard and a video would play explaining how to adjust that item. the video is an flv in a player component that plays on top of the menu and then when complete (here's my problem) it should disappear/close and reveal the menu.
do you know what script i'd use to close the flv playback component upon completion. there's a videoevent close script, but i don't know how to execute it (if that's the right solution). maybe a flv cue point could trigger it? any advice?
here's the current script:
stop();
import fl.video.VideoPlayer;
import flash.events.MouseEvent;
import fl.video.*;
mon_flv.visible = false
mon_btn.addEventListener(MouseEvent.CLICK, monClick);
function monClick(event:MouseEvent):void
mon_flv.visible = true;
mon_flv.play();
Johan le Roux
Re: AS 3.0 flv playback: close upon completion
on Nov 13, 2008 at 10:50:46 am
maybe look here:
http://www.laflash.org/forum/archive/index.php/t-1418.html
walt landy
on Nov 13, 2008 at 3:53:20 pm
hi johan,
thanks for taking the time to respond. i really appreciate it.
i just solved the problem with help on another board. here's the code:
stop();
import fl.video.*;
mon_flv.visible = false;
mon_flv.play();
import fl.video.VideoEvent;
mon_flv.addEventListener(VideoEvent.COMPLETE, hideVideo);
function hideVideo(event:VideoEvent):void
mon_flv.visible = false ;
mon_flv.seek(0) ;
Johan le Roux
on Nov 24, 2008 at 8:24:47 am
Simple and effective way of doing it yes. great. Johan.
