Inverted Mask
COW Forums : Adobe Flash
Steve Ganem
Inverted Mask
on Oct 30, 2008 at 2:57:32 pm
Im sure Im missing something simple as Im new to Flash... I created a shape with the pen tool to use as a mask. For some reason when I turn the layer into a mask it is masking out the opposite of what I would expect. How can I invert it?
Thanks in advance.
Flash CS4
Sam Mattern
Re: Inverted Mask
on Oct 30, 2008 at 6:41:27 pm
The mask should be a fill, not an outline. In other words, a solid shape as opposed to an outline.
Best of providence,
Sam
Steve Ganem
Re: Inverted Mask
on Oct 30, 2008 at 8:05:28 pm
Thanks for your response Sam. It is a solid shape I created with the pen tool and fill. The stroke is off...
It worked correctly (cutting a hole in the jpeg blow it where the "fill" was) until I turned the layer off and on a couple of times. Now its masking the opposite "inverted" which makes me think I switched an option someplace.
Best,
Steve G
Sam Mattern
Re: Inverted Mask
on Oct 30, 2008 at 8:36:31 pm
Did you accidentally flip-flop the layers? Your mask layer should be above the to-be-masked layer, which should also be "inset" to show it is being masked.
Best of providence,
Sam
Steve Ganem
Re: Inverted Mask
on Oct 30, 2008 at 8:55:49 pm
I double checked and the layers are in the correct order... Still having the issue.
Steve G
steve@run-dontwalk.com
Sam Mattern
Re: Inverted Mask
on Oct 30, 2008 at 9:01:19 pm
Try locking the layers. Is it not showing correctly when you test, or just on the stage?
Best of providence,
Sam
