project for cs4
COW Forums : Adobe Flash
jesse harris
project for cs4
on Oct 22, 2008 at 7:28:40 pm
ok was using flash project file to batch publish 20-150 files.
still can do but....
1. it opens them all individually publishes closes.... unlike just output text showing it did it like cs3.
2. i have to check off all 10-10000 files i want to publish individually, there's no "select all" box that i can see(or shift/ctrl function).
3. its a flash file that doesn't re-size when you shrink it.
i know batch publishing is not the major function of the projector but it was the only reason i used it and for these functions it fails. due to slower and less easy to use(at least my first 3h using it)
anyone know how i can fix or do/not do these???
or if adobe made a better way to batch publish.
thanks. love other functions so far too much in bones to get into.
cs4 flash animation = after effects + flash + 3d software(you pick) x 3.14.....
