Aspect Ratio Settings in Flash8?
COW Forums : Adobe Flash
Charles Smith
on Oct 16, 2008 at 9:36:30 pm
I'm having issues with the aspect ratio in Flash8. I'm importing a 16:9 .avi video into Flash8 and want to resize it to 50% of its size which would be 360X240. But when I check the flv file for playback, the video looks squeezed from the sides. I've tried manually setting both Horizontal & Vertical and then trying the "keep aspect ratio" but it still squeezes.
What am I overlooking? I've looked at the help files and not much help. Anyone have a hint?
Charles Smith
Re: Aspect Ratio Settings in Flash8?
on Oct 16, 2008 at 10:20:03 pm
Turns out I've found a solution elsewhere. For the benefit of others who run into this situation, here's what I've found to work:
16:9 HDV aspect ratio needs to be resized to 400 X 224 in Flash 8.
For more info, click this link:
© 2018 All Rights Reserved
