New to flash and video - need help please
COW Forums : Adobe Flash
Phil Parkin
on Oct 4, 2008 at 2:31:23 pm
Hi there - imported .mov into flash - added skin - saved flv and exported swf - embedded swf into web page using swfobject. Video works fine EXCEPT:-
The video starts on page load, but I want the user to have to start it. Played around with play="false" param to no effect.
Also video ends with blank screen. I want it to end on last frame with something in it or on an image.
Sorry about basic nature of the questions but any help out there for this beginner much appreciated - thanks.
William Sticht
Re: New to flash and video - need help please
on Oct 7, 2008 at 1:17:25 pm
Phil,
Go back to you fla and select your video component and then go to the windows menu and open the components inspector and make sure the autoPlay option is set to false. Not sure about the end frame other than edit your video to have the image you want as your final frame.
Fritz
