Help! with transitions
COW Forums : Adobe Flash
Mario Mendez
on Sep 25, 2008 at 11:51:37 pm
My goal is to trigger an OUT animation whenever someone clicks on a new button in my website. However the only way I can make work is by replacing each button on each page with a new goto script.
Is there a script that will play an out animation when a button is pressed and then takes the user AFTER that animation plays to the page the button they chose should take them?
I hope thats clear. Any help would be boon. Its the last hurdle I need to fix before my website is complete so please help asap.
Thanks SO much
Simeon Albertson
Re: Help! with transitions
on Sep 29, 2008 at 8:27:19 am
If you are using Tweener, you can use the onComplete event to take the user to another page after the animation has played.
end = function ()
trace ("Transition ended!");
Tweener.addTween(myMovieClip, {..., onComplete:end});
© 2018 All Rights Reserved
