swapping movie clips
COW Forums : Adobe Flash
Kenn Macintosh
on Sep 4, 2008 at 4:31:06 pm
I'm using CS3 with AS2.0
My flash movie is playing an animation on the left side of the screen. While that is playing, the user can click on 4 buttons on the right side of the screen to view animations on a pump, valve, bearing or cylinder. I need to keep the animation on the Left side of the screen going while swapping out the animations on the right. My timeline is 2000 frames long. 0-1000 is the animation for the BLUE filter, then when you swap out the BLUE filter with the BROWN filter, it jumps to frames 1001-2000. Initially I thought of putting each of the right hand screen animations on a seperate "scene" and linking to each of those via the buttons using "gotoAndPlay(Scene,lable)". Is there a more straight forward way to approach this? You can view what I have at present from the link below. None of the bottons on the right side of the screen work at this time.
http://www.animationsunlimited.com/webmovies/crw.html
Thanks, Kenn
