Passing Parameters to Flash
COW Forums : Adobe Flash
Gil Balbus
on Aug 29, 2008 at 5:01:22 pm
I need to Pass Parameter to Flash Movie.
I read this:
Step 1
Open the fla and replace the text box with a dynamic text, set the variable name to "mytext" in the property panel (note: you should set the variable name not the instance name). Then export your movie.
Step 2
Edit the page that contain the flash movie. Select the flash movie and append "?mytext=something" to the swf file name in Dreamweaver's property panel. (if you want to edit the html code manually, you need to look for the swf file name in both the and tag.)
Step 3
Test your HTML page! You should see the movie is now showing whatever you put as "something". Test more by changing the "mytext=" parameter in the HTML page.
in my flash file I got 10 variables named: line1 .. line10
now I tried to edit the movie.html and set those things that written in step2 to this:
embed src="movie.swf?mytext=HELP" quality="h....
and than I saved the file, and run the movie.html file.
but it didnt work, it didnt change the variable line1 HELP
How to fix it?
what's the problem here?
Thanks, Gil
© 2018 All Rights Reserved
