Scrolling Thumbnail Panel AS3
COW Forums : Adobe Flash
Harrison Willett
on Aug 25, 2008 at 2:50:21 am
I am trying to add Lee Brimelow's Scrolling Panel to my site which is in AS3 but I ran in to some problems I have:
panel_mc.onRollOver = panelOver;
function panelOver()
this.onEnterFrame = scrollPanel;
delete this.onRollOver;
var b = stroke_mc.getBounds(_root);
function scrollPanel()
if(_xmouseb.xMax || _ymouseb.yMax)
this.onRollOver = panelOver;
delete this.onEnterFrame;
var ydist = _ymouse - 442;
panel_mc._y += ydist / 7;
And when I test the file I get a swarm of undefined Properties:
including _xmouse, _ymouse &, _root
What do I need to do to make AS3 happy
Thanks in advance
Clint Milner
Re: Scrolling Thumbnail Panel AS3
on Aug 27, 2008 at 2:37:31 pm
That tutorial is in AS2.0
You could try switching the AS version in the publish settings window.
I'm trying to get my head around AS3.0 and finding that there's quite a few changes to learn.
Harrison Willett
on Aug 28, 2008 at 2:55:22 am
I actually figured it out... just took a while
Ian Cooley
on Oct 3, 2008 at 5:59:57 pm
how did you do it, if you don't mind me asking. I am having the same problem
thanks
ian
Harrison Willett
on Oct 6, 2008 at 12:45:26 am
panel_mc.addEventListener(MouseEvent.ROLL_OVER, panelOver);
function panelOver(event:MouseEvent):void
stage.addEventListener(MouseEvent.MOUSE_MOVE, panelMover);
function panelMover(event:MouseEvent):void
if(event.stageY > 171 && event.stageY < 711 && event.stageX > 61 && event.stageX < 248)
panel_mc.y -=(event.stageY - 441)/ 42;
if(panel_mc.y >= 191.3)
panel_mc.y = 191.3
if(panel_mc.y <= -676)
panel_mc.y = -676
Keep in mind I am using the actual position on the stage instead of the get bounds..... I did this as i was first learning as3
I bought a great book from lynda.com called ActionScript 3.0 for flash CS3 Professional check it out it helped me understand enough to make that scroll bar on my own :)
Harrison Willett
on Oct 6, 2008 at 2:44:09 am
if you want to call the mask mask_mc you can use:
var b = (mask_mc.getRect(this));
if(event.stageY > b.y && event.stageY < (b.y + b.height) && event.stageX > b.x && event.stageX < (b.x + b.width))
this allows you to not use specific points in space in case you want to move it down the line
Greg Hollowell
on Dec 12, 2008 at 4:47:28 pm
Hey all, I tried that same goToAndLearn tutorial to make a scrolling thumbnail panel, and found your posts very helpful. I tried the following (Flash CS4 w/ AS3):
panel.addEventListener(MouseEvent.ROLL_OVER, panelOver);
function panelMover(event:MouseEvent):void {
if(event.stageY > b.y && event.stageY < (b.y + b.height) && event.stageX > b.x && event.stageX < (b.x + b.width));
//I definitely remembered to change the mask instance name to mask_mc, and I got the following error many many times:
TypeError: Error #1034: Type Coercion failed: cannot convert global@e2050f9 to flash.display.DisplayObject.
at MethodInfo-1()
at MethodInfo-1()
at MethodInfo-1()
I can't figure this one out on my own. Any thoughts? Thanks!
