.flv won't play in flash player?
COW Forums : Adobe Flash
Christopher Grosso
on Aug 17, 2008 at 8:39:32 am
I am not a Flash guy but I have Flash CS3. I use After Effects quite a bit and exported a .flv from AE. When I click on :Open with...flash player" flash player opens but the file does not.
I have a free download called "SWF & FLV Player" and it plays fine in that. Am I missing something here?
Produce | Shoot | Edit
Take Two Visual Media
http://www.take2vm.com
Pieter Helsen
Re: .flv won't play in flash player?
on Aug 17, 2008 at 11:45:38 am
Flash player can only play .swf files. It can't play video formats of any kind (including .flvs). To play an .flv you need either an external player like VLC Media Player or the one you have, or, you can import the .flv into flash, load it into an flvplayback component (this is all done when you go through the File > Import > Import Video... wizard) and then export it as an .swf
Kind regards,
Pieter
General notice: from now on, I would like to ask everyone to put [AS2] or [AS3] (corresponding to the version of actionscript you are using on your project) in front of their post titles when the question is actionscript related! Please help us help you faster. Thank you.
