SWF file is causing the CPU to run at 100%. how do i fix??
COW Forums : Adobe Flash
Ian Gadson
on Aug 7, 2008 at 2:26:01 pm
Hello,
I was wandering if you might be able to help me with a Flash problem. I have an swf file running at the site listed ( http://www.xaviertechgroup.com ) the animation is causing the CPU to run at 100%. The file is an XML file. I don't have a clue as to why the swf file is causing this to happen. Any help would be greatly appreciated.
igadson
