Can AS2 and AS3 work together?
COW Forums : Adobe Flash
Clint Milner
on Aug 4, 2008 at 9:22:48 am
I'm more comfortable in AS2.0, but I was able to make a really cool AS3.0 swf with a tutorial. I'm wondering if the majority of my site is using AS2.0, if I can externaly load the swf using AS3.0 if it's all in Flash 9?
Clint
Sher Ali
Re: Can AS2 and AS3 work together?
on Aug 4, 2008 at 9:31:43 am
No you cannot load AS3 swf file in AS2 swf files because AS2 swf files use AVM1 while AS3 swf use AVM2.
Sher Ali
Flash & Flex Developer
website: http://www.webeyestudio.com
blog: http://www.kabulinteractive.com/blog
My FlashDen Portfolio
Andrea Dolas
on Jun 27, 2009 at 12:55:41 am
Does this also mean that we should not have AS2 swf files and separate AS3 swf files on the same site or page?
Thanks in advance!
Pieter Helsen
on Jun 28, 2009 at 9:02:21 am
Sher wasn't entirely correct. There is something called the SWFBridge, this allows AS2 files to communicate with AS3 files.
http://www.gskinner.com/blog/archives/2007/07/swfbridge_easie.html
Anyhow, to answer your question, no, that's definitely not a problem. Each SWF file operates on his own. In a different instance of the Flash Player.
Kind regards,
Pieter
General notice: from now on, I would like to ask everyone to put [AS2] or [AS3] (corresponding to the version of actionscript you are using on your project) in front of their post titles when the question is actionscript related! Please help us help you faster. Thank you.
