Animated arrows as mask
COW Forums : Adobe Flash
Jeff Cochran
on Aug 1, 2008 at 7:48:06 pm
Hello all:
I'm trying to do a rather complicated mask in flash and can't quite get it right. I have a line with four arrows on it. The arrows travel in circular pattern. Between the arrow heads is a small white space. I need to build this as a mask because the color of the arrows (the entire graphic) has a gradiation from red to blue.
Does anyone have any suggestion to make this work?
Thanks in advance.
Tony Ross
Re: Animated arrows as mask
on Aug 1, 2008 at 7:54:54 pm
Hey Jeff-
I would use a movieclip or graphic as my mask, that way I could make the movieclips/graphics timeline more complex with multiple layers.
Hope this helps
Tony
