[AS2] Flash site not working when uploaded - Help Please!
COW Forums : Adobe Flash
Sabrina Crayne
on Jul 29, 2008 at 8:30:00 pm
I am trying to uploaded this flash site and it worked once, then I noticed something I wanted to change, now when I reload everything it the flash won't play.
I thought I was doing everything the same way. but no flash.
The first time I uploaded and then tried to access the site I was told there was no index page so I pulled the html fiile out of the Folder and I got a index page, but no flash, so I pulled the swf file out the folder and Viola! I had my site, but since I re-uploaded after making some changes, no matter what I do I have an index page but no flash.
Any ideas what I am doing wrong?
Sabrina
Sam Mattern
Re: [AS2] Flash site not working when uploaded - Help Please!
on Jul 30, 2008 at 1:05:33 pm
Sabrina,
It's most probably a problem with the the code in the HTML:
1. Make sure that the filename is exactly the same as the one that worked, and you won't have to change the HTML.
OR
2. Publish a new HTML from the new FLA
OR
3. Open the HTML file and there will be 3 or 4 references to which SWF to embed. Just do a search for "swf" and it will take you to the first spot. There will be two spots referencing "filename.swf" and two just referencing "filename."
Hope that helps.
Sam
Sabrina Crayne
on Jul 30, 2008 at 2:08:36 pm
Thanks Sam! I've got it now.
Sabrina
