Transparency
COW Forums : Adobe Flash
Mohammad Taghi Karimi
Transparency
on Jul 13, 2008 at 8:43:19 pm
Hi
Every Second A New Post
In My New Project I Want To Make Layers Like Windows Vista
you know
i've 2 layer
1-bg
2-my box
i want evry thing under the box layer be blury and i know the alhpa
but the ...
thanks
Just Try To Be Best Until You Death
Never Give Up For Any Thing
http://www.mtkarimi.com
Pieter Helsen
Re: Transparency
on Jul 13, 2008 at 9:26:28 pm
What I would do is create two backgrounds.
First you have your regular background, then copy that background onto a second layer above it. Convert it into a movieclip and go to the Filters panel. Add a blur to the image. Then, create a third layer on which you place your box. Now right-click the third layer and set as a Mask. And, last but not least, you'll need a fourth layer for the contents of your box that aren't supposed to be transparant.
Basically, you're doing this in reversed order.
Kind regards,
Pieter
