Sound control in multiple FLVs
COW Forums : Adobe Flash
Bruce Wilson
on Jul 10, 2008 at 2:33:26 am
Here's what I want to do - 2 flv side by side in the same swf - both running at the same time, both with audio. I basically want to have a mouse over / out situation where the swf loads, both flv's play. Initial state I guess will have to be both audios off.
I want to be able to mouse over one flv and have it's audio on; on mouse out I want the audio to stop, on mouse over the other one the audio plays and mouse out it stops. Meanwhile the flvs continue visually. The flvs will be different lengths and looping.
A perfect example, in Quicktime, is here http://professordvd.typepad.com/my_w...rhizomeOne.mov
Anyone here who can give me a (detailed) solution?
Thanks for your time.
Alvaro Castaneda
Re: Sound control in multiple FLVs
on Jul 13, 2008 at 10:13:38 pm
hi
there you go
import fl.video.*;
flvplay.addEventListener(VideoEvent.COMPLETE, loop);
flvplay2.addEventListener(VideoEvent.COMPLETE, loop);
function loop(event:VideoEvent):void
flvplay.play();
flvplay2.play();
flvplay.volume = 0;
flvplay2.volume = 0;
flvplay.addEventListener(MouseEvent.MOUSE_OVER, soundOn);
flvplay.addEventListener(MouseEvent.MOUSE_OUT, soundOff);
function soundOn(event:MouseEvent):void
flvplay.volume = 1;
function soundOff(event:MouseEvent):void
flvplay.volume = 0;
flvplay2.addEventListener(MouseEvent.MOUSE_OVER, soundOn2);
flvplay2.addEventListener(MouseEvent.MOUSE_OUT, soundOff2);
function soundOn2(event:MouseEvent):void
flvplay2.volume = 1;
function soundOff2(event:MouseEvent):void
stop();
i have to flvplayback components on stage on named flvplay the other flvplay2 , just add you own two movies to them an roll
varomix - pixelEater
http://www.intelianimate.com
Bruce Wilson
on Jul 14, 2008 at 9:55:53 pm
Mr Castaneda thank you very much for your reply.
This code will indeed do the job well. I had no idea how to do it.
Thanks and regards
Bruce Wilson.
