actionscript login IF/ELSE problems
COW Forums : Adobe Flash
Jake Boone
on Jul 4, 2008 at 2:26:51 pm
I'm hoping someone with better actionscript knowledge than I have can help with this-- I've got a password login using the following script:
on(release){
if(password == "X"){
getURL("website address");}
else {
gotoAndPlay ("try_again");}
Two problems-
The first is that when the correct password is entered, the "if" funciton correctly happens (website opens) AND the timeline advances to the "else" function ("try again"). I hope this makes sense.
Secondly, I'd like the URL to open in the same window as the swf file- any code suggestions would be appreciated. For a look at how I'm using the file see:
http://9yardsphoto.com/photos_commercial.html
Thanks all!
Sher Ali
Re: actionscript login IF/ELSE problems
on Jul 4, 2008 at 3:53:07 pm
to open the url in the same window you can do use the target parameter with _self value, like:
getURL("website address","_self");
I am not sure what is wrong with the login issue as I don't have the password to test the link you have provided.
Sher Ali
Flash & Flex Developer
website: http://www.webeyestudio.com
blog: http://www.kabulinteractive.com/blog
My FlashDen Portfolio
Jake Boone
on Jul 4, 2008 at 4:55:47 pm
Thanks Sher- I actually tried "_self" without luck, but it seems to be working now.....
And try "light" for a password- that should work (and right before it goes to Flckr (this is a temporary URL obviously), you'll see "try again" briefly appear)... again, any tips would be appreciated.
